CS6 brush size under 1 pixel?
COW Forums : Adobe Illustrator
Alistair Gallop
on Jul 29, 2012 at 2:35:43 pm
In CS6, it doesn't seem possible to set the brush size under 1 pixel (i.e 0.5px). Does anyone know how to fix this as I require finer brush strokes than 1 pixel?
Cheers
Ali
Vincent Rosati
Re: CS6 brush size under 1 pixel?
on Aug 21, 2012 at 12:45:38 am
Could you create your own brush that is smaller that 1 pixel, or set the brush size to a very small decimal in the brush palette options.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
