Vector or not vector, that is the question
COW Forums : Adobe Illustrator
Mat Chevitz
on Jul 18, 2012 at 4:33:17 pm
Hi there,
I received this document from a graphist, done in Ilustrator. Look at the A, why do I have pixels here, although this is vectorized ?
I thought it was ok, but when I import it in AE for animation it's not good at all... I should have miss something in Illustrator
Thanks !
Editor, MotionDesigner
http://www.cebri.fr
MacPro 2x2.8 Ghz Quad-Core Intel Xeon
8 Go DDR2 FB-DIMM 667 MHz
Mac OS 10.6.7
Nevin Styre
Re: Vector or not vector, that is the question
on Jul 23, 2012 at 7:42:06 pm
What type of file did he/she give you? vector files are typically EPS or AI (also PDF or SVG).
In AE when working with a vector layer from a file make sure you enable the "continuously rasterize" checkbox on the layer or pixelation will occur if you enlarge it past 100% the default size.
Mat Chevitz
on Jul 23, 2012 at 8:55:24 pm
I did enable the "continuously raserterize" button in AE.
The source file is an AI file.
Actually, the screenshots I posted are from Illustrator.
The thing is when I zoom far from 100%, like 6400% the letter looks ok. But when I'm close to 100% it looks bad...or maybe it looks the way it should be, but that's not how I thought vector letters would be.
I don't get that.
http://www.cebri.fr
Mac OS 10.6.7
Nevin Styre
on Jul 23, 2012 at 9:20:03 pm
In Illustrator preferences do you have "anti-aliased artwork" checked off? turn it on if it is off(it's in the general preferences). In after effects next to continuously rasterize there is also a quality switch, make sure you set that one to the solid "/" icon as the other setting disables anti-aliasing as well.
Mat Chevitz
on Jul 23, 2012 at 9:40:35 pm
Anti-aliased is off and the quality icon is on the right side...
The problem is in Illustrator. When I use the Text tool and write something, my text looks good.
The problem is the path itself, from the graphic designer. Maybe he used a bad font, or he did something wrong with the vectorization.
He made several text with different font each time. Some are bad like the one I showed you, but some are good...
I think I should try to talk about it wth him now...
http://www.cebri.fr
Mac OS 10.6.7
Joseph W. Bourke
on Sep 16, 2012 at 11:29:15 pm
Something many graphic artists don't understand is that just because a file is saved in Illustrator, it's not necessarily a vector-based file. I've requested vector-based artwork from people, and had the same nasty looking results, only to find that the person thought all you had to do was open or import a bit-mapped file into Illustrator, and save it as an eps or ai file, and it was now vector-based. This is not the case, and it may be what you're dealing with.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
