Lines appear when using patterns
COW Forums : Adobe Illustrator
Charles Roberts
on Jul 9, 2012 at 8:56:37 pm
Hi - I'm hoping someone can help me..
When I fill a shape with a pattern (in this case 'smooth wave') very fine lines appear in the fill.
I guess they might be created between tiles (?).
I've uploaded a screen grab. The lines are VERY fine, but do print out unfortunately.
Anyone know what I can to to lose them?
Thank you in advance,
Charles
Vincent Rosati
Re: Lines appear when using patterns
on Jul 9, 2012 at 11:29:35 pm
Typically this is just a screen rendering issue, but you point out that you also see the issue in the print.
Most likely, you'll need to edit or possibly rebuild the pattern.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
