Illustrator CS6 - Not Precise
COW Forums : Adobe Illustrator
Jeremy Wick
on Jul 3, 2012 at 9:31:16 pm
I am unable to move or re-size objects in small/detailed amounts. Also, smaller objects are not getting perfectly centered when I align them to the artboard. All the "snap-to" are off. I never noticed an issue with this in CS4. Am I missing something?
Vincent Rosati
Re: Illustrator CS6 - Not Precise
on Jul 3, 2012 at 11:33:36 pm
Maybe check the options menu in the Transform palette and see if you have "Align New Objects to Pixel Grid" checked. I think this was introduced in CS5.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Kenneth Brøgger-Luplau
on Apr 26, 2014 at 11:04:48 am
Thank you!!
