about Illustrator cs5 clipping masks 2
COW Forums : Adobe Illustrator
edgar hudon
on Jun 22, 2012 at 3:06:08 am
please read my other post before if you havent
I wanted to make sure i was clear so ive decided to show the exact problem;
4323_assis.jpg.zip
you see the spot of liter red between arms and legs thats what i want to extract from the mask
thanks again
Vincent Rosati
Re: about Illustrator cs5 clipping masks 2
on Jul 3, 2012 at 11:51:08 pm
The attached file illustrates a method...
4354_assisv10.ai.zip
1
Make your masks.
2
Select the interior components and Object / Arrange / Send to Back.
3
Select your front and back vectors and Window / Pathfinder / Minus Back.
4
Select everything and Object / Clipping Mask / Make.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
edgar hudon
on Jul 4, 2012 at 2:52:05 am
thanks a lot lot to have taken the time!
clear and precise,
it was simple but i wouldnt have found it on my own
im so thankful!
