Changing size of logo created with brush shapes
COW Forums : Adobe Illustrator
rose falgout
on Jun 7, 2012 at 10:59:48 pm
Hello,
I am new to illustrator...
I created a logo with brush shapes and when I try to resize larger or smaller the logo doesn't look like the original design.
I have grouped the shapes together but it still changes shapes.
Thank you very much...
RF
Tylor Larson
Re: Changing size of logo created with brush shapes
on Jul 4, 2012 at 5:00:13 pm
to solve this issue you need to double click the SCALE tool... this should bring up a dialog box for the scale tool... at the bottom of that box there is a check mark for scale stroke and effects.. with this on it will scale the brush stroke when you scale your object.
TY
Nicole Nel
on Jul 24, 2012 at 6:29:46 pm
Convert the paths to outlines. Select and then go to: Object - Path - Outline Stroke.
If that doesn't do the trick then go to (with the object selected): Object - Expand.
