How do I punch out sections of a pie chart?
COW Forums : Adobe Illustrator
Ignacio Holiday
on May 8, 2012 at 12:12:16 am
This is my first time trying to make a pie chart in Illustrator. I have a black donut shape that I want to slice into pie sections. So I made a rectangle over the circle, then rotated it around the pie I combined these sections into one shape. But when I delete the pink star shape it removes it as though it was a layer on top of the black donut. What I want is for it to remove the shape and cut the pie into slices. (See my pics). Can anyone help tell me what I'm doing wrong?
Vincent Rosati
Re: How do I punch out sections of a pie chart?
on May 8, 2012 at 12:19:20 am
You probably want to use Pathfinder / Minus Back..
http://forums.creativecow.net/search.php?q=minus+back&f[]=245
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Ignacio Holiday
on May 8, 2012 at 12:49:17 am
Okay, but I'm not sure what to have selected when doing this. I'm getting "the filter produced no results-please select two intersecting paths." This happens when the star is selected, and when the star and donut are both selected.
Vincent Rosati
on May 8, 2012 at 1:06:26 am
Basically, you select two objects, then do Minus Back. You may have to do this a number of times, for each operation.
Vince
