NURBS Curves imported into Illustrator?
COW Forums : Adobe Illustrator
James Skrous
on Apr 9, 2012 at 10:34:46 pm
Hi everyone,
I would like to know if there is a script, or software or plugin or any method where I could import Maya NURBS curves into Illustrator. I find Maya's NURBS so easy to work with and I can do art so much faster, but obviously there's a lot more you can do in Illustrator after the line work is done. So far the only method I could find is to use Maya's Vector render. But this dose not follow my original line work, (it traces it) so there are a lot more points then I would like and the vector work just isn't as clean. Also when it opens up in illustrator the art work usually acts a little weird. Its also just a lot of work sometimes to create NURBS patches, so that there is something to actually render. So any suggestions?
Nicholas Mallinder
Re: NURBS Curves imported into Illustrator?
on Mar 30, 2013 at 8:47:12 am
I would definitely like to know this as well. I've been using illustrator for years and have just been introduced to cv curves. Instantly got better lines.
