Point Type Scaled for Area Type
COW Forums : Adobe Illustrator
Kian McKellar
on Apr 1, 2012 at 5:11:22 pm
I often create area type and then wish to scale it similar to what I do with point type. Instead it just adjusts the area which the text can be within. Is there anyway to free transform an area type box? I feel that sometimes I've gotten this to work but I have no idea how. Thanks in advance.
Vincent Rosati
Re: Point Type Scaled for Area Type
on Apr 1, 2012 at 7:43:37 pm
Select the text box than click S (Scale tool). Then it will resize the box and the text that is inside it.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Kian McKellar
on Apr 2, 2012 at 2:35:55 pm
Thanks. Been searching for that shortcut for a while.
David Cabestany
on Apr 4, 2012 at 4:08:44 pm
You can also use the transform tool for that.
I also often create a quick shape right next to the text box, a square or something like it, I select both together and scale down to what I need, then I delete the square.
I know it sounds like too much a hassle, but I'm so used to it that I do it probably faster than using the scale tool.
Kian McKellar
on Apr 18, 2012 at 2:35:58 pm
Hmmm, interesting. I'll have to try that.
