Need some advice in illustrator
COW Forums : Adobe Illustrator
Lucas Vollebergh
on Mar 28, 2012 at 10:54:00 am
Hi Guy's!
I want to make something like this http://galaxy.fili.nl/ (all the triangle's)
Is there a simple way to do this in illustrator?
(Colours etc,)
I'm a beginner in illustrator..
Thank's!
Vincent Rosati
Re: Need some advice in illustrator
on Apr 1, 2012 at 8:22:27 pm
Looks like that graphic was probably created in a 3D app. Naturally, you could make something like that by drawing a bunch of triangles, and position all of the points with View / Snap to Point enabled.
As far as coloring it, you'd just have to do it piece by piece.
There are a number approaches you could take.
One might be to simply set color and transparency for each piece.
Another might take this a step further by duplicating the finished triangle components and Pathfinder / Unite. Then place the united component in a layer below the main component. Then you could fill the united component with an interesting gradient or something. Then for the main triangles you could experiment with different transparency modes.
3932_triangles.ai.zip
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Scott Roberts
on Apr 5, 2012 at 5:07:53 am
I'd make filled triangle shapes, overlayed over each other and transparency - either opacity variations or blending modes.
LittleBlackBird.net
