Making a circle semi-transparent
COW Forums : Adobe Illustrator
Alex Williams
on Mar 23, 2012 at 12:39:18 am
Ok if I have roughly 10,000 circles, all of the same color, and I want to make them semitransparent (i.e. set each to have an alpha value of 0.5 or something like that), is there a way to do that in illustrator?
Vincent Rosati
Re: Making a circle semi-transparent
on Mar 23, 2012 at 11:08:53 pm
Maybe just selecting all of the objects and setting the Opacity to 50% in the Transparency palette (Window / Transparency) would do the trick.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
