making shape look "indented" in sphere
COW Forums : Adobe Illustrator
David Morin
on Mar 20, 2012 at 2:29:05 am
I have a sphere and i want to create a custom shape on it that appears to be in the sphere. How can i achieve this? As you can see i have a basic setup but the outlines are showing in this.. I think im close but need a bit of guidance. Thank you
"how to make this better"
Vincent Rosati
Re: making shape look "indented" in sphere
on Mar 23, 2012 at 11:12:23 pm
Sounds like you just want to remove the black lines - Just select all of the objects, then near the bottom of the Tools palette you'll see the Fill & Stroke controls. Click the small double-arrow so that the Stroke is in the front, then click the None button below it (the small square with the red line).
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
