Create anchor point automatically at two intersecting paths
COW Forums : Adobe Illustrator
Anil Agarwal
on Mar 7, 2012 at 2:00:09 am
Any scripts? Any ideas to be able to do this automatically?
Thanks.
Vincent Rosati
Re: Create anchor point automatically at two intersecting paths
on Mar 8, 2012 at 12:32:58 am
Selecting all of the objects and Window / Pathfinder / Outline might work for you. Other than that, the only thing I can think of is to turn on snapping and use the Scissor tool.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Anil Agarwal
on Mar 8, 2012 at 1:27:06 am
Worked perfectly as described. Thank you, Vincent.
Frances Milne
on Aug 18, 2015 at 8:28:19 am
Thank you Vincent! - I'd been trawling trying to find something to create a simple triangle diagram with no success and this worked quickly and easily.
