Smoothing Bezier corners.... how?
COW Forums : Adobe Illustrator
david lincoln brooks
on Jan 12, 2012 at 3:54:59 am
Hey Vince,
When you convert an anchor point to have 2 Beziers on either side...
Is there any command for smoothing out the angle of the two Beziers once you've shaped their curves the way you like it?
For example, let's say curve left is a more acute angle than it should be to complement curve right...
Does ILLUSTRATOR have a "smooth angle at anchor point" command?
Thanks, Dave
The only things which matter in life are Art and Children. (Georges Seurat)
Vincent Rosati
Re: Smoothing Bezier corners.... how?
on Jan 12, 2012 at 5:10:20 am
If you've converted the curve to an angle or simply just have angle points, press Shitf+C or select the Convert Anchor Point Tool within the Pen Tool buttons, then click on the anchor point and drag it to turn it back into a curve.
Conversley, if you have curves and you want them to be corners, you can again use the tool to click on the anchor points.
I hope this is somewhat close to answering your question.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
