Overlapping objects shadow Issue
COW Forums : Adobe Illustrator
Putopian vohra
on Jan 7, 2012 at 6:22:54 pm
Hi all
I have an issue with overlapping objects.
To make a chain with circles (like olympic logo) I duplicated the object and placed it in same place. After that I erased some part of the top object. But this technique is not enough; as I need to add a shadow for the circles.
3501_shadowoverlap.ai.zip
Can anyone suggest a solution?
Putopian Vohra
Vincent Rosati
Re: Overlapping objects shadow Issue
on Jan 9, 2012 at 12:02:47 am
See the attached file...
3514_shadowoverlapv2cs4.ai.zip
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Putopian vohra
on Jan 9, 2012 at 5:44:04 am
Thanks Vince !
I thought various options to solve it.
It looks very simple after your help.
Vincent Rosati
on Mar 19, 2012 at 2:19:10 am
Example:
Vince
