merging shapes into one object before applying a stroke
COW Forums : Adobe Illustrator
Alexandre Brandt
on Nov 26, 2011 at 12:05:01 am
Hello All,
I've been doing a logo where I letters where converted into object so I could modify their shapes.
I've been tweaking around and I have some letters that overlap, all white, to make it look like a seamless logo word. I'd like to now apply a stroke to it (to have a little simple black contour).
I tried joining the connections between layers but it tells me ; "This selected objects cannot be joined as they are invalid objects (compound paths, closed paths, text object, graphs live paint group).
What am I doing wrong ?
Thanks for reading.
motion pictures + storytelling = ?
-> FILMMAKING !
Vincent Rosati
Re: merging shapes into one object before applying a stroke
on Nov 26, 2011 at 10:20:29 pm
One thing you could try is to select the objects and Pathfinder / Unify.
Or, to just add the appearance of a stroke, duplicate all of the objects and group them. Then layer them underneath the primary objects. Then you can apply a stroke to the grouped objects, and the primary objects will appear to have the stroke.
Just a couple of ideas.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
