COW Forums : Adobe Illustrator
Mustafa Aydınol
on Oct 20, 2011 at 9:59:27 pm
When we duplicate and rotate an multicolored objet repeatedly, when we come to the last object, it breaks the pattern.
Is there an easy way to do it in a proper way?
Here is what I do: I select all, divide by pathfinder and paint the areas that disarrange the path manually.
Hope someone can help.
Thanks a lot
Vincent Rosati
Re: Overlapping
on Oct 20, 2011 at 10:15:30 pm
The easiest way might be to create a new pattern object (the leaf) that includes the cut-away. Either by using a clipping mask or actually cutting it with the pathfinder tool.
Then regenerate the rotation.
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
© 2018 All Rights Reserved
