Masking
COW Forums : Adobe Illustrator
Joel Gamble
Masking
on Aug 18, 2011 at 7:13:24 pm
I'm new to Illustrator, and can't figure out how to achieve a masking effect. My project file is attached, if you want to take a look.
Basically, I am trying to use those black figures as cutouts, revealing transparency behind. Is there any easy way of doing this?
Joel Gamble
Re: Masking
on Aug 18, 2011 at 7:27:39 pm
Edit: here is the file: http://dl.dropbox.com/u/13895316/mhi_logo_metal.ai
Tylor Larson
Re: Masking
on Aug 18, 2011 at 9:36:19 pm
Thanks for the brain melting question. ok... this is a pain but here is the work flow... you need to create a solid matte that is just want you want to show... AKA the gray area... then select the top group of your logo, and copy that new solid matte into that group as an "opacity mask". look in the transparency pallet. please note how your layers pallet changes... this is because you have drilled down into the groups opacity. to get back click on the left preview thumbnail in the transparency window.
this tutorial explains it better then i can.
http://www.bittbox.com/illustrator/opacity-mask-basics-illustrator
just remember that the matte needs to be white for 100% opacity and black for 0% opacity... this is also a great way to do highlights.
if you cant get it to work just repost and i will "yousendit" the file to you.
Ty
Joel Gamble
Re: Masking
on Aug 18, 2011 at 10:41:26 pm
Thank you so much for your help, Tyler. Hope your brain heals quickly! :)
