Artboard question
COW Forums : Adobe Illustrator
Marcus Lovitt
Artboard question
on May 30, 2011 at 4:37:51 am
Hi everyone,
I just received this from our printer:
"Your illustrator data came without crop marks, and one art-board is horizontal while the other is vertical. Below you'll find a 55x90mm template for you to use with your data. You'll need to send us either both vertical (portrait) or both horizontal (landscape)."
It's a business card template. Can anyone give me simple instructions on how to do this (I'm relatively new to Illustrator).
Cheers,
Marcus
Scott Roberts
Re: Artboard question
on May 31, 2011 at 1:19:10 am
Sounds like you're doing a two-sided business card. Make both sides horizontal, or vertical, so the printer knows the correct orientation.
LittleBlackBird.net
GraphicsDump.com
Marcus Lovitt
on May 31, 2011 at 6:23:52 am
Hi there,
Thanks. So is it simply a case of selecting all, doing a cut and paste to their template, then rotating using transform?
Marcus
