Special Continuous Inner Path Effect
COW Forums : Adobe Illustrator
Douglas Kerr
on May 17, 2011 at 12:51:40 pm
Hi All,
I am trying to create a continuous path from the outline of a shape that then moves inside the outline spiralling towards the center of the object, essentially filling the inside shape. I am looking for an automated way as manually, i skew the angles and ends up messy and I have I have lots of vector shapes that need the same effect. The end result needs to be 1 continuous path. Would it be possible to create a script to do something like this? Thanks for any suggestions.
Here is a bad example to give you a rough idea, except without the connecting lines. http://tinyurl.com/6hnsrej
thanks, Doug
David Cabestany
Re: Special Continuous Inner Path Effect
on May 20, 2011 at 3:45:24 pm
Use the offset path command, Object>Path>Offset path.
You can assign a shortcut to it, so you don't have to go the menu each time.
