technical drawing grid effect
COW Forums : Adobe Illustrator
Lucy Orgill
on Feb 7, 2011 at 7:17:43 pm
Hi There,
I originally posted this under the Indesign Forum but I think the Illustrator one is probably more relevent!
I need to make an illustration similar to the one attached
which was taken from a photographthe one I want to do is a photo of a train
I can trace around a photo without problems in illustrator but I was wondering if there is a way to get the 'grid' lines could this be done in illustrator easily or another program first and then the lines traced? if I need to get another software programme please could you advise?
Any advice would be great.
Thank you
Lucy
les nemeth
Re: technical drawing grid effect
on Feb 11, 2011 at 1:10:09 am
That's called a 3d wire frame, and you create it with a 3D program. There are free ones (Blender), moderately priced (Silo ~100 bucks) or more expensive ones. Google is your friend!
But if you've never used a 3D program, get ready for some learning curve!
Lucy Orgill
on Feb 13, 2011 at 2:10:56 pm
Hi Les,
Thank you for the advice, I will look into these!
