problem with anchor points added to stroke
COW Forums : Adobe Illustrator
Karolina dziewanna
on Feb 6, 2011 at 3:39:30 pm
Hi, this might be a simple problem, but I tried to look for a solution and could not find anything. I have a trial version of CS5, and while drawing, using self-made brushes, suddenly they turned into an object with numerous anchor points. Whats more, they become a separate object with the fill they outlined before. How do I remove this annoying feature, and how to prevent from accidental conversion?
Thanks in advance.
les nemeth
Re: problem with anchor points added to stroke
on Feb 11, 2011 at 1:13:16 am
Well, you probably accidentally expanded the brush.
