Question about window illustrator
COW Forums : Adobe Illustrator
Hannah Benbow
on Jan 31, 2011 at 1:28:31 am
How do I get the window to go back to normal? It's stuck under the top part. I know photoshop has a button that you can just make it fit back to screen, but I can't find it on illustrator.
Here's what I mean.
And this is what I want back
David Cabestany
Re: Question about window illustrator
on Feb 4, 2011 at 10:21:21 pm
the shortcut is the same as photoshop, the letter F, it cycles between window with top header and top menu, top menu w/o top header and full screen w/o top header and top menu.
also you can try hitting Tab so you hide al your panels, including the control panel which is the one hiding the top of your window, after that you can just drag it down.
