Apply gradient along stroke?
COW Forums : Adobe Illustrator
Marty Hoedjes
on Nov 27, 2010 at 9:06:51 am
Suppose I have these two paths:
And I'd like to give them a 3D effect by having a gradient along the edges.
But the only thing I can think of is making an art brush with a gradient, which I can't do. (If I expand appearance, I lose opacity.)
Is this at all possible?
Greetings,
Marty
Vincent Rosati
Re: Apply gradient along stroke?
on Nov 27, 2010 at 6:17:22 pm
Maybe something like this would work...
1329_offsetpathblend.ai.zip
Select the main structure, then Object/Path/Offset Path to a negative value.
Select both objects and Blend with Specified Steps.
Add points where necessary, so both objects have the same amount of points.
Set the color of the outer blend object to a darker tint color.
Set the outer object transparency of the highlight object to zero.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Vincent Rosati
on Nov 27, 2010 at 6:22:48 pm
Inner or Outer glows might also work.
These could also be saved as Graphic Styles that you could apply to multiple objects if necessary.
Vince
Josh Kirtland
on Dec 27, 2010 at 6:01:30 pm
If you select the object and go to Object>Path>Outline Stroke you should be able to get what you want. Hope it works out for you.
Marty Hoedjes
on Dec 27, 2010 at 10:03:36 pm
Obviously you have not read or not understood my post.
Garry Mathers
on Apr 6, 2012 at 1:56:45 pm
select both objects
go to OBJECT>BLEND>MAKE
voila - a lovely gradient blend
Garry
http://www.ninedesignstudio.co.uk
