turning text into stencils
COW Forums : Adobe Illustrator
john crossfield
on Nov 4, 2010 at 10:54:35 pm
Hi, new to illustrator doing most things in p/shop. I need to prepare a bunch of text ready for a laser cutter to use to cut out the letters as stencils.
So, I know I need to create outlines. Then on certain letters I need to add bridges(so the hole in the o for instance doesn't fall out). I tried to do this by drawing two thin rectangles but what I need to do is use these rectangles to separate the letter, effectively creating two seperate shapes, ie, the top of the o and the bottom of the o. Does this make sense? I'm sure it's a really easy thing to do but I'm missing it.
Please help
les nemeth
Re: turning text into stencils
on Nov 5, 2010 at 8:11:47 pm
Sorry but it doesn't for me. Maybe you could illustrate in PS (or even a pencil sketch) of what are you trying to do.
© 2018 All Rights Reserved
