How to draw vortices?
COW Forums : Adobe Illustrator
arya dirgayasa
on Nov 4, 2010 at 8:54:09 pm
I really need to finish drawing these picture before the end of this week.. I know a bit about illustrator, just to make a simple diagram or schematic. Never before trying to do these. I know how to make the sine profile, but I am lost in trying to create the vortices..(see attached figure)
Vincent Rosati
Re: How to draw vortices?
on Nov 4, 2010 at 9:14:30 pm
Try reattaching. If you used 'File Upload', there's a box that has the link code. You need to add this to your message.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
arya dirgayasa
on Nov 4, 2010 at 9:43:03 pm
I tried the image upload, it does not work
1247_illustratorforum1.jpg.zip
Vincent Rosati
on Nov 7, 2010 at 6:17:10 pm
I realize you're probably past your deadline at this point, but...
It's hard to say how you should draw these.
It depends on what they need them to look like.
Do they need to be line drawings, or do they need color, shading, etc.
I would say, you're probably going to need the pen tool, at least.
One of the general rules in drawing is that you draw what you see.
You can import the raster image, put it in it's own layer, and lock the layer. Then draw on top of it in another layer.
Depending on how many details you would need, it could potentially be a complicated illustration, or not, depending on your approach and desired result.
Vince
