2d text along a 3d path
COW Forums : Adobe Illustrator
Paul Finch
on Nov 3, 2010 at 7:22:34 pm
I need to create text in either Illustrator or QuarkXpress with the illusion that it exists on a wall photographed at an angle.
I imagine that I have to put the text on a 3d plane or in box that can be swiveled in 3D to match the angle of the wall. In the result the closer text would be larger than the text further on down the wall in the distance.
Any ideas?
Paul
Vincent Rosati
Re: 2d text along a 3d path
on Nov 3, 2010 at 7:37:34 pm
See if the attached file on this thread might do what you are talking about...
Text Wrap Corner of Box
It uses Object/Envelope Distort/Make with Top Object.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
