How to remove noise flicker from the borders of an object???
COW Forums : Adobe Illustrator
shay yellin
on Oct 25, 2010 at 7:25:15 am
Hi there everyone,
I'm very new with illustrator, so this is very basic:
I'm drawing a normal graphic drawing in illustrator, which i then want to use in Adobe Premiere for a video clip.
When i insert my finished illustrator image i made (as PNG) into Premiere - i find it's outline borders with a lot of noise and flickering...:-(
Attached is a sample JPG from Premiere showing the problem.
I would be grateful for any insight and tips for solving this problem!
Shay
Vincent Rosati
Re: How to remove noise flicker from the borders of an object???
on Oct 25, 2010 at 11:43:49 am
I'm guessing this is a transparent PNG. Maybe try saving the image as a PSD, and use that in the Premiere Project.
Also, regarding the flicker, I'm guessing you mean video flicker on a CRT display. If so, you could right click on the clip in the Premiere timeline and select flicker removal, or otherwise vertically blur the image from 1.5 to 2 pixels. There's plenty more on this issue in the Premiere forums.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
shay yellin
on Oct 25, 2010 at 11:54:29 am
thanks a lot Vince!
that solved the problem...:-)
Great day for you!
les nemeth
on Oct 26, 2010 at 2:52:59 am
You can use PNG, just make sure it's 24bit. The snapshot looked like it was only an 8bit PNG.
