Crop Marks do not work as in CS3
COW Forums : Adobe Illustrator
zak peric
on Oct 12, 2010 at 12:07:27 am
I have a problem which is relating to Crop Marks option in CS5. In CS3 if I did not select anything and used Create Crop Marks I would get crop marks around the size of my page. I always did this in order to export my images from Illustrator to Photoshop so that the page is exactly the same from one to another program. If i have over spilling square in Illustrator and want to export this to Photoshop I end up seeing the whole sqare rather the part of the square that is inside of the page. How do I tell illustrator not to see anything that is outside of the page. This was such an easy things to do in CS3. What am I doing wrong.
les nemeth
Re: Crop Marks do not work as in CS3
on Oct 14, 2010 at 6:39:21 am
In the Save As dialog, on Image Size tab, check Clip to Artboard.
