convert compound paths to seperate layers
COW Forums : Adobe Illustrator
Joel Arvidsson
on Sep 21, 2010 at 1:20:01 pm
Hi Is it possible to select serval compound path layers and convert then to separate layers? Say you have a layer that contains alot of compounded pathen you want to bring into After Effect and be able to animate all compounded pathes indivually. I guess theres a simplier workflow than create a new layer and drag and drop a compounded path to that. Then keep doing this to all compounded pathes have their own layer.
joelarvidsson@gmail.com
les nemeth
Re: convert compound paths to seperate layers
on Sep 21, 2010 at 9:45:30 pm
Select (hilite) the layer, click palette menu > release to layers (sequence)
Joel Arvidsson
on Sep 22, 2010 at 8:20:52 am
Thanks les nemeth! This saves alot of time waste that can be to into the creative process instead.
