measuring curved paths
COW Forums : Adobe Illustrator
Ruth Hewson
on Aug 13, 2010 at 5:34:56 am
This is a huge thing for me as I have just started making all of my clothing patterns in illustrator.
I need to know how to measure the length of a curved line. I don't want to know the distance between the two points, I need to know the length of the line...
Vincent Rosati
Re: measuring curved paths
on Aug 13, 2010 at 6:02:43 am
Google:
illustrator path length
There are a bunch of plugins that will do this for you.
Try 'em out and let us know how they work for you.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Ruth Hewson
on Aug 13, 2010 at 7:53:15 am
Thankyou!
I had been searching google with "curved path measurement" for ages and hadn't come up with anything but after i searched illustrator path length I found a great free plugin called Path Area by Telegraphics and it works great :D
Nick Wingate
on Jul 17, 2012 at 8:11:40 pm
I am trying to utilize PathLength for illustrator CS4 and I am having trouble seeing how to use it. Any hints?
les nemeth
on Aug 13, 2010 at 11:08:40 am
1. Window > Document Info
2. Open the palette menu
3. Check "Selection" and "Objects"
4. Select your path
5. Read the length of the path
