Newbie question about edges
COW Forums : Adobe Illustrator
Les Kaye
on Jul 27, 2010 at 7:00:11 pm
Apologies about not searching prior to posting - but I'm not even sure what to even search for, and I've hit the ground running on a graphics job (I'm an experienced video producer/editor without Illustrator experience). So here goes:
I'm using one of the .ai templates as a starting point. There's a mask with 4 rounded corners. I've placed new graphics in various positions on top of this mask, but cannot figure out a way to get any of the squared corners of the the new graphics to fit a matching underlying rounded corner.
I hope I've explained it clearly.
-Les Kaye
http://www.leskaye.net
les nemeth
Re: Newbie question about edges
on Jul 28, 2010 at 6:43:46 am
The mask has to be on the top of all objects that you want to mask! (since you said you placed the other objects on top of the mask)
Les Kaye
on Jul 29, 2010 at 6:58:56 am
Thanks for the responses. I'll see if I can get the suggestions to work - the problems of modifying an already created template...
LK
