How to deform text
COW Forums : Adobe Illustrator
Mike Throck
How to deform text
on Jul 22, 2010 at 8:23:33 pm
I'm trying to deform my text in a way slightly different from the envelope presets, I just want a different shape.
Anyone know how to deform text into this shape, with out any weird distortion from moving keyframes around on the envelope?
Vincent Rosati
Re: How to deform text
on Jul 22, 2010 at 8:35:28 pm
You might just have to Type/Create Outlines and drag the points into position.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Mike Throck
on Jul 22, 2010 at 8:37:11 pm
I'll give it a try, thanks.
Mike Throck
on Jul 22, 2010 at 9:43:11 pm
Should I convert to outlines, then use an envelope?
Is there an accurate way to do this?
Vincent Rosati
on Jul 22, 2010 at 11:08:42 pm
You would probably still get the distortions that you are concerned about, if you use a warp.
You could also try a mesh, but that might also have the distortions.
With either of these methods you wouldn't need to convert to outlines.
Sometimes you just have actually illustrate stuff. In Illustrator you can control positioning down to 0.001 pt, which is quite accurate I think.
Depending on your needs, you might also need to add Bezier curves to the bottom points of the text.
The attached file shows results from a couple of different methods.
I think that doing it by hand has the best potential.
archv10.ai.zip
Vince
