Rough Edges
COW Forums : Adobe Illustrator
Dirk D. Lopez
Rough Edges
on Jun 9, 2010 at 8:44:17 am
Hello I'm trying to roughen up my vector box in Illustrator but I'm not having a lot of luck with the "Distort>Roughen Effect".
Any tips on how to better arrive a "rough vector edge" look like on the box here:
http://cl.ly/1KMK
Vincent Rosati
Re: Rough Edges
on Jun 9, 2010 at 8:24:57 pm
Usually that type of thing is better done in Photoshop.
But to do something like that In Illustrator, you could use the rectangle tool to draw a box, then apply a Brush to the stroke, from the Brush Palette.
There are a bunch of brush libraries in the drop-down menu.
You would probably also have to Object/Expand to match the color.
Or, you could Live Trace an actual photo that has the rough edge that you are looking for, or perhaps a scan of your own brush strokes.
Just a few ideas.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Dirk D. Lopez
Re: Rough Edges
on Jun 10, 2010 at 5:18:19 am
Thanks a lot for the reply. I guess I just really need to dive in and work with those brushes. Im not too familiar with them. Thanks again for all the tips!
