How to create DNA graphic?
COW Forums : Adobe Illustrator
Jordan Yaruss
on Jun 8, 2010 at 2:42:09 pm
Hi all. Can anyone give me some tips or point me to a tutorial on how to recreate this DNA graphic? Sorry for the low quality.
Vincent Rosati
Re: How to create DNA graphic?
on Jun 8, 2010 at 3:46:21 pm
Helix 2
Helix 3
These show all of the techniques you will need.
However since the waves are repeating pattern, you could probably start with a straight path and apply Effect/Distort.../Zig-Zag, Smooth...
After you Object/Path/Outline Stroke the shaped path, you could offset a copy of the expanded shape and use Pathfinder/Subtract Back to create the lighter colored/front shapes to create the shading.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
