outer glow disappeared
COW Forums : Adobe Illustrator
Laura Shapiro
on May 24, 2010 at 10:14:37 am
Hi, All.
I used an outer glow effect in my illustrator project. I saved it as a pdf. When I open the pdf in acrobat, the outer glow appears normal. When I open it in preview, the outer glow is so faint, it's hardly visible. Is there something I can do to fix this discrepancy? Can I save the file in a different way so that the glow will be consistent?
Vincent Rosati
Re: outer glow disappeared
on May 30, 2010 at 7:16:21 pm
I'm sure that if you saved the file as a raster image you would see the drop shadow.
That would work, but I'm kinda' being a smarty pants.
If your subject is white and you just can't see it in the preview, maybe you could add a layer in the file with a dark background.
I don't think that Adobe ever liked the idea that Apple added PDF support to Preview, so perhaps there are just going to be some limitations.
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
© 2018 All Rights Reserved
