Measuring the 'arc length' between anchor points on a curve
COW Forums : Adobe Illustrator
Hannes Nehls
on May 19, 2010 at 8:57:41 am
I'm wondering whether there is a way to measure the 'arc length' (geman: Bogenmass) of a curve in Illustrator in any way. I was doing some intense research on this matter, but couldn't find any source dealing with this. It might be just be all to obvious - I still can't find the way.
I'm doing some sewing patterns and this functionality became all of a sudden highly desirable : )
Would be wonderful if someone could spread some light on this matter.
Thanks a lot, Best, Hannes
Hannes Nehls
Re: Measuring the 'arc length' between anchor points on a curve
on May 19, 2010 at 10:18:26 am
Problem solved: Key was to search for 'path length'. SnapMeasure from nineblock is quite what I wanted! best, Hannes
