Diffusion on a flat surface
COW Forums : Adobe Illustrator
Serge Leone
on May 5, 2010 at 5:41:40 pm
Hello,
First off - i want to recreate a surface i saw on a flash app.
It´s a virtual clone of a drum-machine.
I don´t really know how they did the surface.
I thought with a gradient mesh and very subtle changings - did not work out...
same goes to 3d diffusion since its flat
anyone got any clues leading me in some direction?
thanks in advance
cowcowcowcowcow
Vincent Rosati
Re: Diffusion on a flat surface
on May 5, 2010 at 7:29:54 pm
Maybe something like this:
http://www.newinelabs.com/rosati/tutorials/illustrator_metal_panel_cs2.ai
It's a radial gradient with a raster brushed metal tile on top. The edges are opacity mask gradients, accessed in the Transparency drop-down menu.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Serge Leone
on May 6, 2010 at 2:07:22 pm
Wow, just wow :)
Thank you very much for your fast reply, even more for the supplied file.
good karma
greetings, mike
