align to artboard problem
COW Forums : Adobe Illustrator
Laura Shapiro
on Apr 25, 2010 at 9:51:33 pm
Hi, All. I am trying to center an object on the artboard. Tutorials online tell me to select the object, choose "align to artboard" in the align panel and click the center buttons. I've tried this several times, but nothing happens. Am I missing a step? Or is there another way to do this? Thanks! Laura
les nemeth
Re: align to artboard problem
on Apr 26, 2010 at 6:15:13 am
That's the way, unless there's something really un-obvious. Such as your object is way bigger than the artboard. Or you might have a corrupt installation or something is funky about your system or your program.
Dirk Westera
on Feb 27, 2012 at 2:26:57 am
I was having the same problem,
My Align options were set to "Align to Selection."
I have changed it to "Align to Artboard" and everything is fine.
These options can be found in the top right corner of the Align window, by clicking "Show Options."
Matthew Robson
on Jul 22, 2013 at 9:49:17 am
Hey that solved it! Thanks!
David Whiteside
on Dec 15, 2014 at 6:15:10 pm
thank you dirk! that worked!!!
