Illustrator CS4 quitting when I try to save
COW Forums : Adobe Illustrator
Adam Bennett
on Apr 22, 2010 at 10:26:39 am
I've tried deleting the preferences and it hasn't made any difference.
Any ideas?
I'm running CS4 on 64 bit pc.
Vincent Rosati
Re: Illustrator CS4 quitting when I try to save
on Apr 25, 2010 at 11:18:17 pm
I don't have a straight answer.. but, try saving:
a blank file
a file with a shape
a file with a little text
It might help to narrow down the issue.
Maybe try disabling PDF compatibility also.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
