knife and scissors tool ?
COW Forums : Adobe Illustrator
Alexandre Brandt
on Mar 18, 2010 at 6:17:18 pm
Hello,
I'm new to Adobe Illustrator, and am currently trying to design a logo with text.
I have text that I transformed to compound path and I'd like to modify some letters by cutting, pasting etc. The issue I have is that in my tool bar I do not find several tools that I was indicated to use by the user guide such I Scissors and knife tool. I looked under splice tool by clicking a few second on the button but only the slice select tool in addition to normal slice tool appeared, not scissors and knife as shown on
http://help.adobe.com/en_US/Illustrator/14.0/WS714a382cdf7d304e7e07d0100196...
Where is the place where I can enable those tools ?
Thanks for your attention !
motion images + storytelling = ?
-> FILMMAKING !
les nemeth
Re: knife and scissors tool ?
on Mar 18, 2010 at 10:40:21 pm
The knife and scissors tools are hiding behind the eraser tool (in CS4).
les nemeth
on Mar 18, 2010 at 10:43:25 pm
If you closely look at the image on that link, you'll find it is correct. On the tools panel, from label "H", you'll see a long line going up to the eraser tool.
Also, in the description text, it is correctly showing under "H - Slicing and cutting tools". There you'll see the the scissors and knife is listed under the eraser.
