Exporting high resol Illustrator layers to After Effects
COW Forums : Adobe Illustrator
Amit Ashraf
on Feb 24, 2010 at 6:11:55 pm
I just created a character on Illustrator which I want to animate on AE. But when I import on AE, the resolution of the AI files are lower than what I want. How can I import a higher resolution version of the AI layers? Or can I change the dpi of illustrator?
les nemeth
Re: Exporting high resol Illustrator layers to After Effects
on Feb 27, 2010 at 1:53:43 am
AI files are vector. If you import a vector file into AE, there's a little button on the timeline that you can check. This will keep the resolution of your imported vector image regardless how big you scale it up. I forgot the name of that checkbox. Just look it up in the manual. It has a little sun-like shape/icon.
David Cabestany
on Mar 2, 2010 at 5:48:27 am
It's called continuosly rasterize switch, it's on the switches panel, right next to motion blur, draft quality and frame blending.
