Pathfinder Problem
COW Forums : Adobe Illustrator
Tia Nyrae
Pathfinder Problem
on Feb 19, 2010 at 3:51:34 am
I use Illustrator CS. My pathfinder used to not deselect the objects after I use a pathfinder option. For example, now when I add two objects together, they deselect instead of staying selected. How can I fix it so that it stays selected after I've used a pathfinder option?
David Cabestany
Re: Pathfinder Problem
on Mar 6, 2010 at 4:00:41 am
Have you tried the options for the pathfinder panel? I know for instance that the brush panel has a "keep selected" option, perhaps the pathfinder has one.
