layer colours
COW Forums : Adobe Illustrator
Angela Fernihough
layer colours
on Feb 4, 2010 at 1:51:03 pm
Hi - this is a problem which is just a bit irritating, not causing huge problems. When I add the fifth layer to an image the path lines are indicated by a yellow line. I find this really hard to see against a white background. I know I can change the colour and I do this each time but to save time I wondered if anyone knows a way to change the default order of the layer colours.
Thanks if anyone does
Angela
Scott Roberts
Re: layer colours
on Feb 6, 2010 at 5:54:35 am
In the layer palette, double click the layer. A window will pop up, allowing you to change the color of the layer.
http://www.youtube.com/graphicsdump
