reset size of foto
COW Forums : Adobe Illustrator
gunnar Kordestani
reset size of foto
on Dec 29, 2009 at 9:11:51 am
hi there,
is there a way to rest a foto back to it's original size in Illustrator?
If you go via >object >transform >scale it starts where u are at that point. So if any change of scale has done yet one cannot say what the original scale was.
thks ...Gunnar
Mike Gondek
Re: reset size of foto
on Dec 29, 2009 at 5:59:42 pm
GOOD QUESTION! Wish they had an easier way to do this simple task. Here is the solution:
Select image > links palette flyout menu > placement options > preserve >> file dimensions
I have not found a solution to remove other transforms (eg: rotation, skew), except using the effect >> distort & transform >> transform. This effect is much more useful than it appears, and have used this as a solution on numerous jobs.
© 2018 All Rights Reserved
