text spline?
COW Forums : Adobe Illustrator
Bill Morris
text spline?
on Dec 9, 2009 at 6:56:07 pm
Is there a way of creative a single spline running through brush script, or any cursive, connected text that mimics handwriting? I don't want an outline, but rather, one single line that runs through the middle of the text. It looks like it can be done with brush strokes.
Vincent Rosati
Re: text spline?
on Dec 9, 2009 at 7:41:42 pm
Check the thread "Make a double path one path"
http://forums.creativecow.net/thread/245/860964#860964
I'm not sure if this will do exactly what you want, but it's a possible solution.
Or, you could draw a path with the pen tool.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Bill Morris
Re: text spline?
on Dec 9, 2009 at 7:46:42 pm
Thanks, I'll check it out!
Thie Thomsen
Re: text spline?
on Dec 9, 2009 at 8:38:53 pm
The funny thing is, there are fonts that do this. They are usually used in CAD applications.
i've found a couple of different ones over here, but sadly, they won't work correctly in Illustrator. Something to do with postscript fonts needing closed paths.
http://www.featurecam.com/general/support/engrave_fonts.asp
You could however use these fonts in a cad app (qcad is a decent free one) and import the lines into illustrator (where you can manipulate and stroke them to your hearts delight).
I can see your spot colours...
Bill Morris
Re: text spline?
on Dec 9, 2009 at 8:58:15 pm
Thank you!
