Illustrator cs4 classroom in a book page 94
COW Forums : Adobe Illustrator
Richard Kratt
on Dec 2, 2009 at 12:48:48 am
I can't get past step 3 on page 94 of Illustrator CS4 classroom in a book. I'm trying to connect two paths but the Connect Selected End Points button I'm being directed to use is grayed out. I've googled the problem (and apparently others have had this problem) but have not found a response that helps. Has anyone here worked through this?
Rich
les nemeth
Re: Illustrator cs4 classroom in a book page 94
on Dec 2, 2009 at 7:13:53 am
I don't have that book, but chances are if that button is grayed out, then you have either
- 2 points selected that are already joined
- you have only 1 point selected
- there's a stray point right under another selected point, but you can't see it, so you have 3 points actually selected
Try
1. deselect everything
2. Go Select > Object > Stray Points
3. Hit delete
Now try again.
Richard Kratt
on Dec 2, 2009 at 9:50:35 pm
Les,
I got it working. Thank you for your response!
Rich
