Bending a gradient
COW Forums : Adobe Illustrator
david Cabestany
Bending a gradient
on Sep 28, 2009 at 3:11:09 am
Hello all,
I'm trying to replicate an aluminum tube which has a somewhat related to a funnel shape. I created a nice gradient which mimics the texture and illumination of aluminum, but I haven't been able to bend the light streaks at the bottom, I tried to create a gradient mesh and also blending several objects, but when there is so many color variations, both options get very tricky and yield poor results.
Does anyone can think of a way of bending the gradient fill to follow a certain path or something like that?
Here's an image of what I'm trying to do, I think it's pretty self explanatory:
Best,
D.
les nemeth
Re: Bending a gradient
on Oct 3, 2009 at 12:01:11 am
Use blends. Eg, make 4+ lines as in the figure below. Color them appropriately, then blend:
Blend 1
You can also create fancy blends this way, eg a CD/DVD:
CD-ROM
david Cabestany
on Oct 3, 2009 at 12:33:36 am
Hi Les, thanks for your reply.
Your example is very good, is so simple and practical that made me think: Why I didn't think of that? Clear indicator of a good idea.
Unfortunately I was in a hurry with such project so I ended up creating a gradient mesh that although took me a lot to create it came out nice, but I for sure will try your method next time.
David.
