Trouble Removing cut lines!
COW Forums : Adobe Illustrator
Katie Jarvis
on Aug 6, 2009 at 7:44:48 pm
I have Adobe Illustrator CS3 and i use a vinyl cutter with the software.
When creating layers i expand the path of the original text and place the expanded behind the text to create a new layer. However, when creating the new layer, the cut lines of the text bubble together, making it impossible to cut. I have been getting rid of these cut lines by hand forever, and it's just too time consuming. I want the second layer to be a solid outline, but its impossible with all the cut lines. There has to be a better way!
Please help?
Katie
Vincent Rosati
Re: Trouble Removing cut lines!
on Aug 8, 2009 at 4:05:40 pm
I'm not sure I exactly understand what you are describing.
You outline the text (Type/Create Outlines), and place the outlined text in a layer that is beneath the live text.
I'm not sure what you mean by 'bubble together'
Are you using strokes on your text? Perhaps you need to Object/Expand, before outlining - or after.
Your cutter may also require to save your AI file to an earlier version. Maybe try saving as an EPS.
Just a few thoughts.
Vince
*Please remember to Rate our replies and check Solution if solved. Also, we do this out of love and fun, so its always nice to recieve a Please and Thank You! :)
