I have a problem ,need help
COW Forums : Adobe Illustrator
Panaiot Petkov
on Jul 22, 2009 at 7:27:58 pm
hi i have a problem.
See this tutorial -> http://library.creativecow.net/articles/brown_jason/vector_3d_logo/video-tu...
i use Photoshop for making a logo becouse i cant find this brush for Ai ,and when i save the logo (psd or jpg format) i open it with Ai ,then i select the Direct selection tool and hold SHIFT then click and move but nothings happend only image move ,how exsacli to do it ,or do you know how i made Photoshop Brush for Illustrator ?
Sorry but i'm noob in Ai and Cinema i understand only photoshop
Thank you
zActIve ^^
Paul Hennell
Re: I have a problem ,need help
on Jul 25, 2009 at 12:11:00 pm
I think you need to read up a little on the differences between photoshop and illustrator. Photoshop uses pixels and illustrator uses vectors (which make up paths). If you've ever used the pen or shape tools inside photoshop you'll have worked with paths, but everything else is different.
Opening a jpg in illustrator will just treat it as an imported picture. To convert it to paths (As this tutorial needs), you can either trace with the pen tool, or possibly (depending on how complex it is) use the 'Live trace' feature.
Search around for 'tracing a logo in illustrator' and you should find a fair few video tutorials to walk you through the process.
Only in after effects do children get to pick and whip their parents.
http://hennell-online.co.uk
